Changes the name of an IP Network Address Translation (NAT) rule.
ip | Specifies Internet Protocol (IP). |
nat | Specifies NAT. |
rule | Specifies configuring NAT rules. |
rule_name | Specifies the current NAT rule name. |
name | Specifies providing a new NAT rule name. |
new_rule_name | Specifies the new NAT rule name. |
N/A.
The following example changes the name of the IP NAT rule "old_rule_name" to "new_rule_name":
# configure ip nat rule old_rule_name name new_rule_name
This command was first available in ExtremeXOS 31.2.
This command is available on the switches that support the IP NAT feature. For information about which switches support this and other features, see the Switch Engine v33.1.1 Licensing Guide document.
